Running hours
Dan08212x
212X
Is 109 running hours a lot for 08 212x fresh water only? (M1 motors)
fatboyroy
Sebastian, FL
barely broken in but the possible issue with old boat with low hours it may have sit a long time and have cracked hose and corroded bolts etc. make sure you inspect boat thoroughly and do a water test if youre planning on purchasing
buckbuck
Texas
More than 6 times that on my 212X. I think you have a gem.
anmut
212S
I would rather buy a used boat with a lot of hours than a used boat with low hours. Low hours means it sat... and sat... and sat. Sitting isn't good for any engine. This boat that you mention is 14 years old, and put an average of 8 hours on it a year. That's *maybe* two weekends for us in the summer. To give you some additional stats:
Average "summer" usage is considered about 50 hours.
If a boat was only used 8 hours during an average year (June/July/August x 8 hours a day of useable boat time = 736 potential hours per year), that means it sat for 99% of the summer during usable hours. Was it covered or not? Sat in the water? Were the engines started so oil could circulate and the pistons could be lubricated? All things (and more) to consider on "low hour" boats.
When you go to look at it, inspect EVERYTHING about it. Have them take the spark plugs out (to make sure they come out), look at the clean out ports, look for rust on electronic cables, inspect the batteries, inspect the bucket and steering cables.
Beachbummer
Houston TX
Low hours also means not much wear from use. It probably sat a long time.
As others suggest, inspect it very well. But if all looks great, I would prefer it over a high hour boat.
Scottintexas
Corinth, TX (DFW)
my 2007 has 450 hours and I feel like it never gets enough use,
