Inthrustwetrust
- Destin FL
Looking for a sanity check before I continue ordering parts and going down a rabbit hole. New 2020 AR240, installing a amp and some tower speakers, amp is only going to power the tower. Leaving the stock speakers hooked up as is to the head unit for now. To my knowledge the boat doesn’t have a amp installed, speakers are just wired straight to the speaker/power harness in the back. Yamaha decided to do that proprietary non standard RCA connector and also cut off the sub woofer RCAs, not that I care right now. However, the zone 1 and 2 are hooked up, not sure what they are going to, assuming some sort of volume control with the Connext system up front?
So option 1, get a new power/speaker wiring harness (the stock one also has no wire for the amp on) and splice in a RCA line out converter to the two zone 2 speakers, which is what I want to the tower to be zoned with for fade control.
Option 2-Buy the regular RCA harness. Figure out wherever those non standard RCA cables are going and re wire them with standard RCAs. Add Y splitters to zone 2 out to run to the amp. Re wire the Aux in to a standard RCA as well.
I could pop the head unit off and start unplugging those non standard RCAs and see what functionality I use but I am trying to minimize taking the unit on and off, as I posted in another thread, the factory drilled the holes way to close to the hole for the unit. I don’t want to do more damage, and I don’t have the speakers/amp yet.Option 1 seems the least painful. Curious what y’all think.
