- Ottawa, Canada
- Scarab
- 165 G
Someone posted the idea of using large yoga balls and that got me going. I was going to the yoga ball idea but storing them is an issue for me. So I decided to build the simplest 1/2" PVC pipe structure I could come up with. I felt like I was building lego. lol Anyways, I repurposed the two rubber feet on the current poles and combined with various joints, tape, etc. I managed to replicate the height of the poles. Nothing is rubbing by design and it stands on its own.
The main reason I wanted to do this is because I keep the boat at the dock most of the time. When I put her to sleep for a week at a time, I'm constantly having to remove and add back on the straps of the current poles while trying to put the cover on and tie it to the dock. This allows me to remove all those straps entirely. Should make things easy.
For reference, it's a 165.
P.S. Ignore the super messy/full garage. She hasn't been out this year yet... we're just about to come out of hibernation here in Ottawa, Canada. The cover needs a good cleaning after a winter or projects with dust, particles, etc.
***EDIT*** Added a measurement photo. Take note these measurements are actual cuts. It already accounts for joint insert. Cut exactly as indicated. Should fit pretty damn close. If you add pipe insulation, you may need to shave about 1/4 of an inch off the verticals to accomodate for that a bit.
