Scarab 195 Starter Solenoid Part#
Jacques
Doral, FL
HO Impulse
Hi Everyone,
In case you need it, the Starter Solenoid Part# is: 278003012 for the Scarab 195. I have a 195 HOI but it may be the same across all 195 models, at least it's also used by many Sea-Doos.
I had it changed twice in the first year :rage: when the boat had warranty, hope don't need to use the spare one I bought.
ALAN MANN SR.
Wimauma, Florida
HO Impulse
I have a 165 HO and three times now when I went to start it, nothing. The instrument cluster will sweep, but will not start. After messing with ignition switch, shift lever, emergency cut off switch and checking connections a solenoid, it will start. The first time is when I had pushed off the dock, so now I check to see if it will start while on the trailer. Not sure what the problem is. What made you change the solenoid?
Elio195HOI
Miramar, Florida
Check your safety neutral switch.
ALAN MANN SR.
Wimauma, Florida
HO Impulse
I did check it and I think it is the emergency engine shut off switch causing the problem. Thank -You for your response.
Jacques
Doral, FL
HO Impulse
Sorry for the delay replying, in my case the boat didn't start, just did a click sound, in my case (195) coming from the port side behind the battery where the fuse box and the solenoid is.
I never had problems like yours, it has been only matter of the boat not being in neutral or forgetting the safety switch.
Gzep23
HO Impulse
Hey do you know where it is? I bought the part thanks to you now I need to find it on the engine lol
