Scarab 285 oil change
Jordanet
Does anyone know where to find the oil filter and what type and how much oil the scarab 285 takes. It has the twin rotax?
Do you have the 300’s? I have a 2022 255 with 300’s. The filter is right behind each motor when you lift the hatch, easy to see and get to. 3.2 quarts with oil change , see my attachment.
Thanks so much yes it’s the same motor. Do you know the part number or which type of oil filter do you recommend?
See attached from my order off Amazon
