Scarab tight against winch roller
Joatmon
Estero, FL
255 SE
Ok this is embarrassing because I have been boating for over 50 years, but I have an issue I do not understand.
My 255 25 footer is the largest and heaviest boat I have owned and I thought I knew how to put a boat on a trailer. No matter what I try I cannot get the bow to rest on the winch roller once pulled out of the water. When the boat is winched on the trailer the bow is tight against the roller, but the boat pulls back as I pull out of the water. The bow ends up three inches from resting on the roller. I have had the same issue on four different ramps with different angles and replaced the winch strap because I thought it was stretching. The boat is not sliding back on the bunks. I have tried putting the trailer further in the water and tried wetting the bunks and power driving to boat tight against the roller. Every time the bow is tight against the roller when in the water but then pulls away as I drive out of the water. I tried routing and tightening the strap above and below the roller.
I think the boat is rocking back to match the trailer angle therefore pulling the bow away from the roller. Just don't know what to do about it. Never experienced this before.
Any suggestions?
djetok
Edmond, ok
Any suggestions?
When winching in I always put pressure on the strap with my other hand to keep any potential slack in the reel.
D_scarab_ny
Long Island
I have a 215 and it always happens to me. I actually press hard on my breaks to get the bow back on the roller
Joatmon
Estero, FL
255 SE
I tried that last night. I don't have the brakes to stop fast enough to make the boat slide on the bunks. Thanks for the suggestion.
Scarabpaul
Bradford, Ontario, Canada
In addition to the winch I have a ratchet strap I added at the front, same as the rear strap, it pull the boat down and tight to the roller. I never liked that the trailer never came with a chain so I added the strap.
James McDougall
North Bay, Ontario
Wake
I also have a 215.....This happens to me everytime. I manually torque it forward with pure man strength......takes about 5 or 6 cranks. I wouldn't envy doing it with a 255 though! I also use the brake trick....works occasionally but my Acadia isn't ideal for towing....it works ok, but I'm glad my boat usually goes in a slip and stays there most of the season. We only occasionally take it to other lakes and places.
Joatmon
Estero, FL
255 SE
I finally found the problem with me trailering the boat. The winch mount post was welded on the trailer cocked to one side at the factory. So much so that when I pull the bow to the roller it pulls the boat off center on the bunks. The last time the boat was trailered I noticed there was a gap between the hull and bunk on the front of one bunk which explains why the stern is always pushed to one side. Using jacks I positioned the boat squarely on the bunks and the winch is two inches to the left. A square verifies the manufacturing defect.
I have been dealing with a battery drain issue for a year now I found the Scarab trailer winch post is cocked. I will have to cut the post, center and reweld. This is a galvanized trailer with rubberized coating so I will have to get that all back to looking decent. Very frustrating!
jryan
Sarasota, FL
I had this issue last night as I wasn't able to winch my boat up high enough on the trailer (It winched tight and I felt I was going to break my winch if I cranked any harder). I pulled out of the water onto flat ground and pulled forward at a few mph and tapped the brakes. The boat moved all the way forward and was much easier to secure. I think I may make this part of my usual routine before I leave as I was shocked at how much the boat had left to move forward. Rear straps stayed tight the entire trip home.
Mike Clark
Germantown, ohio
Based on your picture I think your biggest issue is the winch strap to boat hook should go under the roller, not over it.
That alone would keep it from seating correctly. ??
galonuscct
Kentucky Lake
242 Limited E-Series
Exactly what I noticed and was about to suggest. That will help dramatically. Pull the boat up on the roller and then tighten the strap from under the roller before you pull out of the water.
I actually have a running debate with my father in law about this. He's boated his whole life and has been a boat owner with many more years of experience than me and he refuses to place the strap under the roller. Old dog, new tricks analogy applies!
flybackwards
Any suggestions?
I have noticed this every year and tried harder to pull it tight before leaving the ramp - last season it was firm against the roller and then at the to[ pf the ramp there was a three - four inch gap - my conclusion is that the actual trailer is flexing under the weight of the boat. The trailer works well but its not very heavy construction for the weight of this boat.
Joatmon
Estero, FL
255 SE
I have solved my problem. I just have to power through the winching until the boat is tight against the roller. I make sure the fenders are just under water and then armstrong power crank. Tight every time now. I did have to make build corrections on the ScArab trailer. Bunk angle adjustment and winch post straightened.
