Screw/nut size and thread?
UnfixedPyle
212X
I was out on the lake this past weekend, the wind was 10-15 mph which made it fairly choppy out in the middle of the lake. I was bouncing along through the chop hearing a thunking sound (technical term). I started looking around and realized it was my dash panel bouncing every time we hit a wave. I dug into my console behind the steering wheel and found 5 nuts and associated washers on the deck in there. From what I could tell all of the nuts that hold the dash panel into the console had come loose. I put them all back on hand tight with the intent to get out the lock-tite at home and secure them properly. Things got busy and I ended up taking the boat back to storage before I could get to it. One thing I did note while I was on the water was that all of the other nuts inside the console used locking nuts (the type with the nylon inserts). I'm not sure why these did not use that style of nut, but since I won't be able to get tools on them until at least next weekend I figured I should just go buy some. Of course I didn't manage to check what size these nuts should be before putting the boat back in storage. Does anyone out there know what size and thread those bolts are? My boat is a 2022 212XE with the 12" connext screen but I assume any of the 21' or maybe even the 19' Yamaha's boats would use the same bolts/nuts to hold the panel onto the console. I'm also curious if anyone else has had this problem and what they did to keep the nuts from coming loose.
