1WetBoat
- Tampa
This is a weird one, looked thru the forums but couldn't find anything similar.
I was out on Sunday going back to the ramp after spending the day out on the water. Conditions weren't bad, maybe 1 footers coming in at an angle to the bow.
All of a sudden, my Connex screen and the metal ring around it fall out of the pod. I had to drive the boat back to the ramp steering with one hand and holding the connex screen in place with my other hand. It seems as if the "nuts" that the bolts attach to are press fitted in and the plastic around them is what cracked.
Gonna call the service dept to see when I can take it in. Warranty better cover this type of damage, not sure how it could have happened. I boat primarily in the Tampa Bay area, never out in the gulf. And while the bay can get rough, I try not to go out when its too rough.
@adrianp89 when you took your Connex Pod apart, did you notice if those attachment points had any stress cracks.
These were the conditions that day out on the water. I was coming back in around 2pm
