seat to replace table?
hokiesax
SeaDoo
Wake
Is there any option to put a seat where the table would go? We never use the table, but could use a seat there, especially when wakesurfing on starboard side.
anmut
212S
Is your table pole straight? Should match up with any standard seat you can buy from a vendor. I would double check the base mount to make sure it's reinforced enough, especially if the seat was to be used while underway.
jEt_jAk
SoCal
AR195
Use an ice chest that can double as seat. Still not sure why Yamaha removed that seat in 2019.
d_coyne1984
Chanhassen, MN
I was not a fan of that when I saw it either. Seating is always a premium on smaller boats, tables not so much. Taking from @anmut 's idea, you could look at having a custom seat cushion made that would mount to a pedestal base. Keep the pedistal the same height as the rear seat cushion so it would be just like an extension of the existing cushions. Since the table is not a floor mount you would need to install the pedestal base. I would think that if the floor is strong enough to stand on it should be strong enough to put that base in the floor. Maybe @JetBoatPilot would be interested in turning the idea into a kit and selling it if it is practical and enough people are interested.
