Shorelandr trailer light bulb
Thermobrett
Lithia, Florida
SX195
Has anyone changed out or pulled the bulbs for the tail lights/turn signals? Looks like I have a right side tail light out. Turn signal works, but no tail light. Before I go to the storage lot, wasn’t sure if anyone knew the bulb numbers.
Just replace them with leds.
I thought a bulb was out but at the front of the trailer there was a connector that corroded. It was tucked in the beginning of where the frame splits to the two sections of the frame. The connector was cut out and heat shrink crimps were used to put it back together.
That's the connector ☝️☝️☝️
That's the connector ☝☝☝
Yes it was! Since it’s hidden in the frame, its not something you can easily rinse, or spray. Also makes me wonder how the side marker lights are wired in - hoping I never have to figure that one out…
I have a 2016 Yamaha SX240, finally got it out the shop. First over heated when checking it out, Tune up and thermostat replacement. Then discovered frozen steering system. Got that fixed after coming from the shop Starboard engine Communication error. New ECM you'll can imagine what that cost. Hopefully all that behind me. Got a right trailer tail light out and a marker light on the fender also right side. The marker light (amber) near the tongue works. Anyone had experience changing these. I pulled the tail light out and like WTF. It is an LED light. Trying to figure out how to get it off the mount, or do I just replace the whole thing. Cut the wires and mount a new light?
