Simrad Go12 in a 210 FSH
John_D
Sebastian, FL
FSH Deluxe
I had a Garmin 1042xsv installed. It’s slightly wider than the Simrad GO12 XSE due to the button controls, but the Garmin is over an inch shorter. As you can see, there is a little space left underneath mine (you can’t go any higher up on the console since there is a lip at the top), but I’m not sure it’s enough space for the Simrad. If it is, it’ll be very close.
Hi, I'm wanting to flush mount a Lowrance Elite 12 Ti2 in my 195 FSH. My rough cut-in is 12.7/16" X 7.3/4". Your thoughts
Liveto99
New York Hudson Valley
Looks great! 12 inch definitely works. I like how you also put your VHF radio down there. You went with Simrad also?
Looks like the same one I have a standard horizon they make one that is short.It also has the emergency button on it I tell everyone to gets on the boat if something bad happens lift the red door and press the button.
gkallevig
Prior Lake, MN
FSH
John, did you end up in stalling this? I'm looking at the same unit to install on my 2016 fsh 190.
gkallevig
Prior Lake, MN
FSH
Fit like a glove. Really makes a big difference being flush mounted
Looks nice! With mine being a 2016, it looks like I've got a little less room some my toggle switches are vertical. Im thinking it might overhang slightly on the right off I do it. But I'll probably go for it.
John_D
Sebastian, FL
FSH Deluxe
I would suggest you contact the dealer to verify the helm dimensions are the same before investing or cutting into the console just to be safe. Let me know how it turns out.
