seanmclean
- Medford, NJ
- Limited S
Got my chartplotter installed today, thought I'd share some details on the mount as I've seen lots of questions about mounting GPS devices to the 242s. Haven't decided whether or not to install the transducer. That helm is TIGHT, Amp install should be fun.
Mounted the RAM Mount to a piece of aluminum plate (2x6, 0.5" thick). I had started down the road of 3D printing something with the intention of having it machined, but that was getting unnecessarily complicated (and expensive). This worked out quite well.
Started by drilling the ram mount holes through the plate. Fit nearly perfect except for a couple sharp edges
rounded them off pretty easily with a file
On the flip side, mounting hole with countersunk holes
VHB tape to help as a vibration damper (and keep it in place during install
All mocked up, ready to disassemble and paint
Light coats of self-etching primer
Hit it with a couple coats of flat black, let it dry and reassembled.
