haknslash
- Lake Martin, AL
- Moomba
- Other
After looking all around it seems the 5' size is all I could find so I decided to take the plunge after missing a backorder shipment. It seems people are able to surf on this board fairly easy as its designed for beginners. Do you guys think it will be fine for me if I'm 5'10" 230 lbs? What's the worst that can happen if I didn't buy a board that was 5'4" or more inches long? Harder to get up or surf in general? I didn't want to buy a real long board and it be slow after I grasped the learning curve so I figured a 5' board should be a little harder to be stable but will maybe give me a longer lifespan before feeling the need to upgrade as I improve. Did I make a mistake? Thoughts?
Looking forward to trying it out soon!
