bronze_10
- Raleigh / Wake Forest Area..
- SX
the day has come. Selling my dear sx230. Ready for something bigger and slower. On outside adds I have it listed for 28k. (Yes its high but is highly modified and has a 2016 I beam trailer) but for a jetboater.net member ill work a deal.
Here are some of the mods
This is the list off the top of my head,
Garmin GPS chartplotter and side scan sonar.
Garmin 200 vhf radio with distress button
Fusion 750 head unit with two 325 amps.
The plotter, vhf and fusion all talk to each other.
Nema 200 backbone
Swim platform fusion remote.
Battries replace with in the last two years.
Dual battery charger
6 wet sound 6.5 in speakers
4 led speaker light rings
2nd bilge pump 1100 gph
Led nav light and anchor pole
Wet sanded and buffed this spring.
Appolstery in almost perfect condition.
Four cushions have slightly stretched stictching.
One discolored spot on the top of one backrest. from the sun.
Shelf in head compartment.
Portapottie
Extra plug in storage until that shows voltage and has extra power plugs.
Battrie one and two status switch to show voltage.
Battery isolator switch.
Both battries in battery boxes.
A positive and negative bus bar for additional equipment.
A positive fuse block behind helm and a ground bus behind help for additional equipment.
New boat cover (700 bucks)
A 2nd used cover
New side skirts to keep sun off boat.
Seadeck through out the boat.
Red bimini top
Trim tabs
2016 load rite 5 star aluminum i beam trailer.
All led lights.
Led strip lighting on the frame rail to guide boat loading in the dark.
Alloy wheels.
Guide posts with new yamaha covers.
New wheel bearings, races and seals this spring.
Radial tires
Torsion axels.
Ther
e is more I missed im sure.
Nema 200 backbone
Portapottie
A 2nd used cover
Red bimini top
Trim tabs
All led lights.
Alloy wheels.
Radial tires
Torsion axels.
Ther
