Brmorganjr
- Castaic, CA 91384
Well you have all heard about the drought in CA....mostly man made from bad policy...but this is the lake by my house. You can see where the water line should be...but the camera is far away...that is 150' down, They have used the lake in commercials to push climate change BS...they don't tell you that they dropped the lake for Damn repairs.....back to bad policy...if your in a drought you drop the lake an additional 60' to do damn repairs on purpose? Don't always believe what you see on TV...24 miles away is Pyramid Lake....completely full cause it's private property...the state want's them to release water to them...they are a hydro power plant...they asked if the state was sending water down to them and they said no...they release to the lake below that they are dropping...they are sending to their other lake they own and pumping it back up to themselves.....but the 1 3" shad they found in the Delta Chanel last year is getting his water...trillions of gallons of freash water washed out to the ocean....but that 1 little guy is safe....
