Spark issue
BLDave
LS
I’m trying to start the boat it turns over good. I pulled the plugs and found I’m getting spark for only a couple seconds then have no spark and the engine won’t start. What could the issue be CDI coils, or stator?
David Martin
Punta Gorda
Common problem on most no starts................simple would be a bad ground not making good contact..........service manual has testing procedures for bad grounds and failed parts like the Pick up coil ect.........You will need a volt meter and one with an ohm meter even better most are in the 10 to 20 buck range.
Hope this helps a little
Marvin willis
Morehead city nc
What boat? I had to replace the ecm on my old 05 ar230. Good think about two motors is u can switch parts around to find the bad part.
