Speaker wiring question? + - + - HELP
JimmyUSN
PA
OK, I want to put swim deck speakers on the swim deck, WITHOUT AN ADITIONAL AMP, Just using the stock HU.
I'm going to use a switch, to switch from the inside rear speakers to the swim deck speakers, and fade out the front speakers.
I know I can use a 4PDT switch.
My Question is, can I use a DPDT switch and just connect to negative wires together, un-switched?
I might just be over thinking this......
@andy07sx230ho posted some great info on doing this a few days ago. I believe he switched both the positives and negatives but placing a switch in either side will accomplish what you want.
I saw it. Brain Fart......:dead:
