stpetesearayderf16
- SeaRay
- Other
Hi! I've got a 96 Sea Rayder F16 with a Sportjet 120 on it. Everyone says the top speed is somewhere around 40 but I've never come close to it. With just me, maybe 35-6 mph, once (clocked using GPS). I don't keep anything heavy in it.
Here's what I'm looking at:
- Steering is loose. I can hold center but there's definitely give. Any way to tighten?
- Wear ring: I've looked at the impeller and it seems to have good gap but it's metal to metal, and I don't cavitate. Is there a recommended wear ring or method to add mph?
- Prop looks clean.
- Ride plate seal is new.
- Compression is fine.
- Carbs are recently cleaned and running beautifully.
- Gear oil is new.
- Fuel is ethanol free wawa.
- 2 stroke is who cares.
