- Royal, AR
- SX
SPOT is cheap to buy. Currently $75 after rebate. It uses the Globalstar simplex data network at 1.6 Ghz. It is water resistant when not connected to a charger. It has tracking capabilities so your family can watch your progress. It can run from 3.5 to 52 days on a set of batteries depending on frequency of tracking updates and having a clear view of the sky. Service is $150 per year with tracking and emergency signaling. It is $100 per year for emergency signaling only. Total cost for a year is around $225 for the Gen 3 and service. It needs a floating case.
inReach has more expensive hardware but offers Freedom Plans that can be paused. The hardware would cost at least $250 new then service would be around $60 for one month. So a minimum of $310 for a month of usage. Then $60 per year to use in one month in future years. The Iridium network is used. It allows for emergency communication and tracking. The battery life is around 4 days with 10 minute tracking updates. It is IP67 waterproof rated to 1 meter for 30 minutes. It needs a floating case. The unit has a LCD display and has maps on board. @Tyler used one last year and was happy with it.
ACR PLB-375 is a $260 PLB. It operates at 406 MHz and has 121.5 MHz homing capability. The battery has a 5 year shelf life. The battery should allow it to broadcast for 30 hours after activation. After usage the expensive battery must be replaced. It is not capable of transmitting tracking information. It is waterproof to 10 meters for 10 minutes. It needs a floating case. The 406 Mhz band has greater penetration of weather or buildings. This is the real deal for safety gear. There are no service fees. Battery replacement is more than $100 so around $20 a year.
EPIRBs start around $400. They are larger whole boat versions of ACRs. They typically float. They use the same frequencies and have similar battery life. I feel they are more than I need.
What do you guys recommend?
