Spray Lubricants
kgower
Buford, GA
222SE
Yamasheild, Yamaha Lube-ZAll, different application, same? How are they different from White Lithium?
I use silicone spray from the local parts store (Canadian Tire store has their own house brand)...seems to be the same as Yamashield for various lube joints. And lithium spray for grease points and pivots on the jet pump. I also use the silicone spray on the cleanout plugs and hull drain plugs every weekend - keeps the rubber seals supple and water tight.
