Austin0514
- SX
Preface- I recently was given a non running boat by a collegue who moved north and could not take it with him. I was informed that the boat would not run. So I took it upon myself to rebuild it. The port engine was fine. However the starboard was seized and would not turn over. I rebuilt the engine and it turned over perfectly with the starter. I placed the engine back in the boat and reconnected all of the electrical connections. However the engine will not turn over via the key.
Some things to note:
I tested the continuity of the key and the key switch was good( I was getting power to the key)
the starter selenoid is good and engine will turn over if power is directly supplied to it.
when I supply 12 volts directly from the key switch connector corresponding to the selenoid switch, I can sometimes hear a clicking sound from the main pump/relay box in the main electrical box.
im 19, and not very familiar with jet boats so any input would be appreciated!
