Starboard overheat light on. Thoughts needed.
Ajax
St. Louis MO
Pulling into slip today and sucked something up into impeller. Big enough to also mess with bucket control.
Due to current and small space I parked it first before clearing.
Open shutting down engines. Heard 3 hissing sounds, maybe 5-15 seconds apart. Sounded like a whale clearing blow hole. It was sound of cold water hitting something hot.
Cleared jam, and went to restart to blow anything small out. That’s when I noticed overheat light was on.
What am I dealing with here?
Any damage?
How do I clear overheat light? Will it go off when cooled down?
What do you think the sound was?
Thanks in advance, you guys are always awesome.
WREKS
Port Saint Lucie, Florida
Once engine temperature drops, the overheat warning will clear. I would not start that engine until it is determined what may have caused overheat. Usually, engine will throttle down when it overheats. Report back, please
tdonoughue
The Woodlands, TX 77381
The cooling intake is in the jet path. So a big obstruction to the impellers or jet impacts the cooling. If you had not enough water incoming, you may have had water washing in on a hot part, causing your hiss. I agree first let it cool. While waiting, make sure all your debris is cleared.
More than likely when you start up again, whatever was in the way will be gone or shifted enough to get blown out. And then you will have no cooling issue either.
At least most likely. Keep an eye on that overheat light on the way back...
Ajax
St. Louis MO
Thanks.
I cleared the debris but did not have time for engine to cool off and test run. Heading back tomorrow
Seadeals
Greenville, South Carolina
If something blocks water from the white cooling block intake inside the jet pump the engine will lose water flow through the internal cooling channels of the block and start to heat up. The overheat warning will eventually sound (longer if at low RPM). At that point the ecu will limit max rpm to prevent damage to the engine from the overheat condition. The sound may have been the residual water still pooled somewhere in the cooling path running through the channels until reaching a hot part like the exhaust. Thinking the combo of changing attitude to just floating Flat in the water when you shut down and the lack of engine noise helped you notice it.
Ajax
St. Louis MO
Thanks for the feedback,
Is it weird that I never heard an alarm? Light just came on.
Maybe I shit it down before it needed to sound?
So probably no further damage or issues?
Seadeals
No...doesn’t sound like it and you can tell if something isn’t right next time you start it. How long did you let the engine continue to run after the blockage before shutting it down? Also, were you only at low/no wake speeds after noticing the blockage?
Ajax
St. Louis MO
Maybe a couple minutes max. Happened right at the slip. All happened at wake speed or below.
Just to be sure, it was the middle light on the tach, that is overheat correct?
Can’t remember what the one on the right of panel is. I know the one on left is check engine.
I know the
Seadeals
Yep. Here is the tach.
Seadeals
Low oil pressure (for our boat models/years)
Ajax
St. Louis MO
Went back to boat today. All ran smooth. Warm water coming from both pissers and no overheat alarm. Ran for about 20 mins at varying rpms including WOT.
tdonoughue
Another win! Float well...
