bkkevinbk
- SR
Hello All - Problem with starting the Portside motor began intermittently about 6 months ago - you just had to turn the key a few times before it made contact and the engine would start right up but completely dead (no crank at all) until you tried it one or two times. I could hear clicking at the black box in the back so just assumed the starter relay was giving out which of course I never got around to replacing until the engine would not start at all (present time). When it finally died - I was blowing the 20 amp fuse under the round lid as soon as the engine tried to crank. I have checked the battery and connections, hatch kill switches, ignition switches, changed both ignition coils, and starter relay. The only difference is now the 20 amp fuse blows immediately but the engine will crank but not start as long as you keep the key on. My next step was going to be to replace the starter but after combing through the forums - I am thinking it might actually be a stuck impeller or something else preventing the starter from turning freely and causing the fuse to blow. Is that possible? I'm going to try and check that the impeller spins next time I'm at the lake (after freeing the stuck plug). In the meantime - is there anything else I should try or parts I should buy before my next attempt at repair?
I am debating whether to go ahead and pull the engine and replace the starter but from what I've read on the forums - it now seems unlikely the starter is my actual problem. I have also seen a few references to how "easy" it is to pull the engine but if it is anything like getting access to the starter relay - it can't be that easy. Does anyone have a write up or description of how to pull the engine? How much should it cost for a Yamaha dealer to replace the starter? Thanks for any help!
