osins74
- Ottawa
- SX
Hello, yes another steering cable replacement post. I have a 2018 SX195, and in the last couple seasons the steering has become pretty stiff. So after reviewing the various posts decided to order the cable and complete the replacement myself. Unfortunately my boat is still in storage and I’ll only be able to pick it up Saturday Morning, so can’t take a look to see how it’s setup. That being said, this is my first attempt at this type of project so was hoping for some guidance and advice from this forum. The following are the steps that I'll be taking, with some questions as well:
1. Remove the seat cushion and back rest to access the helm compartment.
2. Take note of how the cables are connected to the steering box.
3. Remove the cables from the steering column.
4. Remove the clean-out tray.
5. Remove the cable at the U-connector on the jet.
6. Remove the U-connector from the cable.
7. Remove the nut and washer using the o2 sensor socket.
8. Remove silicon/sealant from interior nut.
9. Once old cable is free, remove gas tank access and cut all ties.
10. Attach new cable to old and feed thru the hull to replace.
- Question: Is it "better" to start from the helm or the stern?
11. Pass cable through transom:
- Couple questions:
- My replacement cable only has one washer, assuming that its for the outside.
- Pretty basic question, what's the best way to apply the 4200 to ensure a proper seal? (I might be overthinking this LOL)
12. Once new cable is in place reconnect to the steering box.
- Question: Is there any additional maintenance that should be completed on the steering box?
13. Reconnect U-connector to new cable.
14. Reconnect U-connector at the jet.
15. Replace and reseal clean-out tray. (Any pointers on this would be welcome as well)
Thanks to all in advance, appreciate the help.
- Couple questions:
