Stoltz Roller - 2019 Shorland'r Galvenized Trailer (2018 242 Limited S E-Series)
Summers420us
Hi guys. Traded in my 2016 AR190 on a new 2018 242 Limited S E-Series. The new boat came with a 2019 Shorland'r Galevenized Trailer.
On my 2016 AR190, I used the Stoltz RP-355 for the center roller and the RP-434 rollers for the outer two. The fit was great with the sharper bow of the AR190. No beating up the trailer to make it fit, and it properly contacted the boat. (https://jetboaters.net/threads/stol...er-dont-care-for-fit-fixed.10472/#post-182532)
I saved this roller set thinking I could use it with the new 242, but the middle roller is way too narrow. The RP-434 rollers look like they will fit great though.
Can someone, with a galvanized trailer for the 24 footers, please tell me what the part number is of the center roller you used? Also a photo of the fit and a note about your install would be great.
Thanks in advance.
I used that on my 24. Seemed a little bit too narrow, but just tighten the bolt and it all comes together nicely.
Is your trailer painted or Galvanized? Wonder if they changed the rollers for 2019.
Galvanized
@seanmclean - Thanks for the shot. It appears that your bow eye does correctly touch the middle roller. Is that correct?
The RP-355 roller fits great on the sharper bow of the 19 footers, but I would like to see more contact for the 24 footers. Anyone else had a shot of one of the other center rollers?
Yep, bow eye rests right up against it. While the boat rests against the bells. I trailer about 45 minutes each way, boat was solid and didn’t rock or bounce at all.
I got an lightly used RP 355 (center roller only) if someone is interested for $12 That includes shipping.
