YamaHog
- Little Rock, AR
- Limited S
So I just pulled my 2020 195S out of storage on Sunday to get it cleaned up, re-install the battery and get ready for the season. Got the dryer sheets, damp-rid, and moth ball packets all removed from the lockers, etc. Washed boat, cleaned and conditioned the seats and was ready to fire it up to test. Boat has 34 hrs on it. At the end of last season, I hit all the exposed metal on the boat and trailer with Fluid Film, added the appropriate amount of Stabil marine fuel stabilizer, and filled the tank with 93 octane.
Turned the battery switch on and the Connext screen lit up. One it finished booting, I had the engine flush hose connected (no air in hose) with water turned off. Tried to start the engine and on the second turn of the key it tried do fire up. Then I got a message on the Connext screen "Stop Engine. Contact Yamaha Service". So I start looking around at stuff and realize I don't have the engine cut-off lanyard attached! lol So after attaching the lanyard, the engine fires up and once running, I start the water flow on the hose. The same Stop Engine error message pops up on the Connext screen again at about the same time water starts to spit out of the engine cooling lines on the side of the boat. So I quickly turn off the water flow and shut the engine off.
I try once more to start the engine up, and this time it fires right up, no error message on Connext, and I flip the valve on my flush hose to start the water flowing again. Engine never sounded rough starting up or anything, and with the water flow going, just like a normal flush post-outing, I let the engine run for about 5 mins or so. Then shut the water off and killed the engine. Disconnected the flush hose and fired it up for 10 - 15 secs and revved quickly to blow out any water.
At this point I think I'm good to go, but wondered if anybody had any ideas about why I received the "Stop Engine. Contact Yamaha Service" error. Possibly software glitch related to the lanyard not being attached initially? Minor obstruction in the engine cooling lines? At the end of last season I flushed the boat really well, so not sure how the lines could have had any obstruction. At this point I'm just trying to explain why I got the error message. Thanks for any input.
