I've seen them mounted under the bench on the port side. Here's one from a 210.I would like to install a 10” IB Sub in my 2017 AR210; i was thinking behind the helm seat but both sides of the bench seat base are not flat.
where others have placed it?
Tia!
How do you like it? And you went, sub->fiberglass boat wall->pvc board, is that correct? The back of the sub cleared the outer hull i'm guessing on the backend? Asking, because, if I install a sub this is where I planned to do it.Thanks to all..i ended installing it under the bench seat, i added a 3/4” PVC board at the back to reinforce the area. I used bolts and nuts to sandwich the fiberglass wall between the sub and the pvc board.
yes, that what i did . There is a lot of room behind the sub (between inner wall where sub is mounted and external hull). Sound is very good as well , the boat free space behind the sub acts like an enclosure…How do you like it? And you went, sub->fiberglass boat wall->pvc board, is that correct? The back of the sub cleared the outer hull i'm guessing on the backend? Asking, because, if I install a sub this is where I planned to do it.
