zibius
- Gatineau, Quebec, Canada
- Chaparral
- VR
Hi, with ROTAX 250 HP on a Chapparal. Its weird that everything is fine, acceleration ok, going on plane. But then i would slow down, and when I want to start up again, RPM ok but no thrust. Impeller is ok, wear ring is not to bad, no big damage. Changed the spark plugs and tubes. What else could I check before sending it to a garage? Thanks
