sugar sand tango extreme
Sirlan Gomes
Sugar Sand
Tango Xtreme
I am having a problem with my 2008 Sugar Sand Tango Extreme Jet Boat. When it is out of the water and connected to the hose at my house, it starts and runs just fine. However, when I bring it to the water, it will run for the first 15 to 20 minutes, then it just stalls out. I had someone look at it, and they told me it could be overheating and not getting enough water to cool down. He then recommended flushing the boat with Barnacle Buster, but that does not seem to have worked. The fuel filter and pump have recently been replaced, along with the oil and spark plugs.
Does anyone have any ideas as to what it could be?
You could put a temp gun on it and see how hot it is when it's running good for five-ten minutes vs. when it's stalling out.
However, I'd think you'd have something else going on. Almost sounds like the fuel is stopping - check your tank vent and your fuel lines for kinks? Is that a carb'd motor - maybe consider cleaning the carb?
We had a similar problem. U have to replace the smaller secondary fuel pump/filter that is black. As soon as you run out of gas, the small diaphragm inside the the pump is ruined and will not let gas flow normally. Whenever put engine under much load it will stall out. Under more investigation, our fuel gauge was off from the factory and showed a 1/4 of tank left even though it was empty. We wound up replacing 3 of filters before mechanic figured out fuel gauge was off. Do not let this engine run out of gas.
