Port0222
- Orono, MN
I tried surfing 2 weekends ago with a landlocked and 800lbs ballast. I was hooked. I have been enthralled with getting a better set up ever since. So today I added an 800lbs in the ski locker. 600 under the port seat as well as the 800 on the swim platform.
When I look back -- it looks like the starboard wave has more push than the port. I have never surfed a true wake boat, so I am not exactly sure what I am trying to achieve, but this does not look right. Thoughts?
On a different note -- my bilge kicked on after some tests, and I opened the hatch and I had water in each well (I run with all plugs in) upon further inspection, the foam at the back of the engine hatch was wet -- anyone have water climbing the swim platform and spilling into the engine bay? That is my only guess on how that happened. Any other thoughts?
Only other thought -- both clean out plugs were full of water. I wonder if the tray above the clean out plugs is not sealed well.
You can see the line on the foam where the hatch seal is. It is pretty wet.
