Surface Mount 7" Chartplotter 230 Series
captainhook
Southern Maryland
Limited
I completed this project last year after having it on the list for several years. I always wanted a chartplotter to class up the dash and electronics in the boat as I've been envious of the 2015+ dash, but I've never liked the tacked on look of a chartplotter sitting on the top of the dash or hanging on the windshield support post and prefer a more OEM look. Any modern chartplotter would allow me to ditch the stock depth finder and speedometer so I could rearrange the gauges and fit a 7" in the center, and the Simrad Go7 looked like a winner.
The issue I always had was that any custom trim piece I used would not match the rest of the trim in my boat, as the trim in the 232 Limited is a faux woodish look so it would be difficult to match with paint. I decided that I would wrap the new trim piece in black vinyl and also wrap the rest of them to match. if I didn't like it, it was easily reversible and wouldn't cost much money.
Unfortunately the stock dash piece was quite a complex shape, and fit into a recessed area in the fiberglass dash so it needed to be very close to the correct shape. I began trying to cut a piece out of plastic board by tracing, but the stock piece isn't flat so it was hard to keep flush on the plastic board when tracing.
I was pretty unhappy with the first iteration shape as the curves weren't right and the edges weren't smooth.
Since I am decently experienced with designing for 3D printing, I decided to give that a go by taking a picture of the dash with my iPhone and then tracing the picture with Fusion 360. That seemed to go well until I cut the designed part into thirds and printed some draft pieces with low infill to perform a test fit. Unfortunately, it seems my iPhone camera lenses were skewing the dimensions and after two or three attempts, I could not get it to fit correctly either. This was a bummer because the pieces would've come up very clean with perfect edges and gauge dimensions.
BD539125-A6F7-417D-8F8F-2E7621A37BCB_1_105_c.jpegF5620333-EC37-48BA-9170-3146815B6EDE_1_105_c.jpeg
I decided to go back to the drawing board on hand cutting the plastic board and I wound up buying a router to clean up the edges from the jigsaw cuts. I decided to cut several just in case since I was doing it by hand. This took awhile routing and sanding and I still wasn't totally happy with it but at some point I had to just call it good enough.
I also went through a ton of options of 3D printed bezels for the gauges to class it up a little bit. These were the final version after toying around with pods and various other shapes that could've acted as sun visors that didn't make the cut. I printed these in ASA and put them over top of the vinyl wrap. I attempted to wrap over top of one bezel in a test but it would not conform well enough for my liking and figured these looked fine in ASA anyway.
Test fit was pretty good and I was happy enough with it to continue. Also, I was very tired of this project by this point. :D
The final product after wrapping all of the trim pieces. This has held up well for a whole season of boating and an off season outdoors. All in all I classed up the dash in my boat and added a nice bit of functionality as well. Ignore the old chartplotter the previous owner installed at knee level, that was worthless in that location and never used.
HangOutdoors
Royal Oak, MI
Very nice job. I wanted to do a similiar thing on my AR210 but neither a 7" or 9" would work in dash with a custom panel. Nice work!
