Surfing AR192 (video)
d_coyne1984
Chanhassen, MN
I borrowed 2 - 350lb ballast bags from my buddy. I had one strapped on the transom and one between the two consoles. I think it would have been better to put the one in the boat down in the ski locker, but my friend thought he knew "best." Not a bad wave, but I was only able to hold it for short periods. My driver (same friend) kept going to fast too so that didn't help. I have 4 guys in the boat with me too and was running about 7000 rpm at 10-12 mph. I really don't like running the boat that hard for that long so I don't know that I will be investing in any ballast systems myself. I am hoping to try it again on my board (O'brien Maha) which is wider and see if that give me enough push.
Eurocat
Edison, NJ
can't see it. Says it's private.
ar240owner
Event Sponsor
Event Sponsor
Vendor
Sweet looks like fun !!
RightStuff
Twin Cities, Minnesota
Moomba
Awesome, thanks for sharing the video!
Where was everyone sitting? Everyone on the surf-side? I think you will get a bigger push if you put one of those bags more to one side (under a back seat, or on top of it), that will list it over a bit and kick up the height of that side a bit more. Put a little curve in the driving and you'll be ropeless on that soon!
I wouldn't worry too much about running the boat with that much weight. Since you aren't going that fast it simply is just revving higher to achieve the same speed without the weight. Now if you were running at top RPMs for that engine then maybe, but at "only" 7k it really isn't any diff than driving at ~30mph (or whatever 7k RPM gets you for MPG) for the boat.
d_coyne1984
Chanhassen, MN
Thanks and sounds like good advise! I will try shifting the bag to the surf side. That probably would make the difference I need. It's never going to be an amazing wave, but hopefully it will be enough to screw around on and keep me happy. As far as seating, I had one buddy jump on the back on the surf side as you can see in the video (not legal in MN, I did yell at him afterwards), and I think I had one guy on each side of the back, plus driver.
RightStuff
Moomba
So much fun to experiment with this stuff, wish I had more time to do it!
Here's what I would try next time:
  • 1 bag under the surfside seat
  • 1 bag on the swim platform
And if you have the same number of people next time
  • 2 people in the bow (maybe one on each side, maybe both on the same, try both)
  • 1 person driving (obviously)
  • Last person sitting behind the driver
