Those type of products do not cure the issue with the jetwash. The wakebooster pushes the water creating a small wake but still aerated. Causes a large drag on the boat. Having rode a wakebooster wave it is more flat wake which might be okay for beginners and children. To truely create a smooth larger wake you need proper ballast setup. Plus a device to deflect the jetwash like a wake wedge. In the earlier years of the wake wedge we did try pairing these types of devices along with our setup and it didn't change anything but add a drag to the boat. The creator Jerry @jcyamaharider can help answer questions you may have.Have any of you tried out the SurfModel wakesurfing system on your AR240/250? Does it work well are moving the jet wash out of the wave? How is it comparable to the Yamaha Wakebooster?
I’m looking at getting 400lb bags on each rear compartment and a mid cargo bag as well for ballastThose type of products do not cure the issue with the jetwash. The wakebooster pushes the water creating a small wake but still aerated. Causes a large drag on the boat. Having rode a wakebooster wave it is more flat wake which might be okay for beginners and children. To truely create a smooth larger wake you need proper ballast setup. Plus a device to deflect the jetwash like a wake wedge. In the earlier years of the wake wedge we did try pairing these types of devices along with our setup and it didn't change anything but add a drag to the boat. The creator Jerry @jcyamaharider can help answer questions you may have.
Wake Wedge for Yamaha Boats
Straight-line Surfing on Yamaha Jet Boats with the Wake Wedge and custom Transom Ballast Bags. Est. in 2014 and going strong with many satisfied customers !wakewedge.surf
What is your boat do you have ?I’m looking at getting 400lb bags on each rear compartment and a mid cargo bag as well for ballast
I’m purchasing a 2016 AR240 with 50hrs in immaculate condition tomorrowWhat is your boat do you have ?
Wow 50hrs on a 2016 is crazy. Good Luck on your purchase !I’m purchasing a 2016 AR240 with 50hrs in immaculate condition tomorrow
I’ll have to post a few pics once I get it. I’m going to test drive this afternoon.Wow 50hrs on a 2016 is crazy. Good Luck on your purchase !
If you get the boat this is definitely a great place for information !
