If it was my boat, I would top it off with some gas and gas treatment.Should I top it off with gas too? What's the average battery reading on these batteries? I'm still on the original battery from when we bought the boat new in 2019. I have kept the battery charged through the years?
It's dead, Jim. Time for a new battery.Tested the battery with a volt meter sitting at 11.7 before trickle charge.
Depends on what kind of battery it is. A decent AGM can go 8+ years. A cheap lead-acid can last 12 months. Unfortunately, Yamaha doesn't ship the boats with batteries, nor does it mandate a certain standard of battery for their dealers - so dealers end up throwing the cheapest crap they have available to them because it helps with their margins.Had good run since 2019. What's the lifespan?
This is correct - one of the reasons I swapped out the passenger side USB charger on our boat with one from Amazon that has voltage directly from the system was to be able to read exactly what the voltage was...The battery is toast. 5 years is a year more than I got out of the first battery in our SX190.
With regards to the voltage reading on the Connext screen -- Ours reads .4v low no matter what. A full battery is 12.7 to 12.8v resting voltage, which reads 12.4v on our Connext. Use a handheld volt meter to confirm battery voltage.
You'll get different answers on charging - most important would be to shut the power off at the battery switch when the boat isn't in use. I always have my three batteries on a NOCO charging system, but I also bring them down regularly with tunes at the sandbar. Some swear you can rely on the stator charging system that comes on our boats to maintain the batteries.So new battery now, how often should this battery be charged in the winter and summer months? And should be disconnected when not use, or is the battery on / off switch good enough?
