SX190 issue
NC2092
I have a 2012 sx190 with 240 hours on it. I took it out 3 weeks ago for this summer and it ran fine for two days. I went to go back out on the boat and it won’t start. It turns over but will not start.
I pulled the first spark plug and went to start it to see if the plug would spark and nothing.
I took it to a service dealer and they called me and told me it was the ECM? is that the same as ECU?
They said they determined it was that because it wasn’t grounded and send electricity to the spark plug to fire them.
sorry I and not very handy but I wanted to ask all of you. The dealer said that the part is on backorder till July 16 and the part alone is $1300 dollars.
just looking for help and trying to understand this. Should I take it to another place and get another opinion? Can I order the part myself and try to save money? Or could it be something else wrong with the boat.
I have Tried a lot of all the basic stuff that people have posted on the forum to see if I could fix it myself and no luck. Thank you for all the help.
marcham
Comox, BC
AR195
If indeed it is the ECM it may be possible to repair it.
Give these guys a call:
NC2092
Ok thank you.
tdonoughue
The Woodlands, TX 77381
Do you have the boat back?
If so, check first the overboard switch by the throttle. Make sure the key is in. Remove it and replace it and see if the engine starts.
NC2092
yeah I did that before. I don’t have the boat back yet. I am still deciding if I want to have them fix it or not. Would the engine try to start even if the ECU was bad?
tdonoughue
Depends on what is wrong with the ECU. Sometimes it messes with the injection and sometimes the spark and sometimes...
But I would hate to have to drop $1300 even on the part.
