SX195 trim tabs
Thermobrett
Lithia, Florida
SX195
Hi All
I have a 2022 SX195 and am looking to add trim tabs. Has anyone had experience with trim tabs on a boat like this, and if so, what is recommended (make/model).
HawaiiBreeze
Oahu Hawaii
Just a question, does your boat not trim out when underway? The stepped hulls of these boats automatically trims out once in motion at speed.
212s
1000 Islands
212S
When did Yamaha start making stepped hulls?
Thermobrett
Lithia, Florida
SX195
The boat planes out OK, but if I don’t have an even weight distribution, I run heavy on one side. I would like to balance the boat out.
212s
1000 Islands
212S
Can you not simply have people move to another seat? Or distribute the cargo more evenly?
I find one average sized adult doesn't make much difference port or strb. Two or more makes a difference and I tell them to move or shift to balance out.
Setec_Fl
I’m considering adding trim tabs to my AR210 and have been reading through all the threads. This one seems to be the most recent activity. I’m not looking to add them to “even out” the boat. I’m wanting them to stop porpoising. 2 ft chop in the river on my ride back can be brutal. I hear these stop that. So what’s the downside to having them? Cant say cost because none of us are in this hobby because it’s cheap 😂
HangOutdoors
Royal Oak, MI
I have trim tabs on mine and now I don't porpoise. I put them on for the exact same reason, to even out the 2ft or so chop. The admiral is so much happier. It is like night and day. No downside what so ever. Just another install.
I have a few threads on here regarding what I did and what I learned while installing. here is one with some close up pictures.
HangOutdoors
Royal Oak, MI
Install is not bad, just takes time to do it right and run the cabling.
marcham
Comox, BC
AR195
Which side tends to run low? Mine was the driver side. I added a 2nd battery on the port side, problem solved.
