Sx210 water flow monitoring
Hux2012
Is there an off the shelf flow indicator that you can get for monitoring the cooling water for the 2022 SX210? Last week hit a patch of weeds and plugged port engine didn't notice till overheat alarm and want to prevent this from happening. I did order a shop manual for the boat to see if there is a test port I could tap. Or just buy something I could just add to the output to give a gallon/hour guage I could read would be nice too.
Hux2012
Found a unit on Amazon that will work with only min modification to the system and yout boat.20220723_131339.jpg
Top Bottom
