Sjetter
- North Texas-Grapevine
- SX
I have been having intermittent starboard starter/starting problems for several months. After replacing the starter relay last week, the problem appeared to be fixed, but after a few hours on the lake the starter failed to shut off with the key. Had to shut off the battery to kill the engine. Upon further investigation I found the positive cable from the relay to the starter loose. I tried every tool that I owned to reach the nut on the terminal on top of the starter to tighten. Unsuccessful. Has anyone had this problem? If so how did you go about reaching the nut to tighten?
