Smassey22180
- Ponte Vedra Beach, FL
- SX
What is normal for the throttles on these boats? Right now, I need to manually hold the throttles if I want them to be at a specific RPM. I may get lucky if I go over by 1000 and then pull back but they probably won't be even. If I tighten the adjusters at the base of the throttle, things get tighter but it is not even at all RPMs. It is super tight at the high RPM and loose at below 5k RPM. Is there something I can replace inside the throttle that will make this better?
Also, My throttles are super sensitive at the lower RPMs. I seem to go instantly from idle to 5k rpm. There is a big dead area just after it goes "into gear" and then a fast jump to 4k rpm unless I push slowly over a 5 second period to find the start of the engine throttle movement. My new shifter and throttle cables are not tight. I assume that the dead area can be adjusted correct?
thanks
Scott
09 SX230HO
thanks
Scott
09 SX230HO
