scopeusa
- Providenciales
- SX
I have been off island for about three months and had to leave the boat on the lift, I normally put it on the trailer in the shop, but this time had no room. I had a guy start the engines every week and he was told to open close the throttles and move the levers fully in both directions a dozen times. He was also asked to lock to lock the steering in the same way but forgot. Yes you've guessed it its mighty stiff. I have searched for "Bruce's list" (but cannot find it) and looked on all of the forum references I can find but I cannot locate the Teleflex cable numbers for the 2008 230HO. Can anyone help? I cannot see any numbers on the cables, they look as if the run across the top of the fuel tank. Do you need to lift the fuel tank floor section to replace these on the 2008 model? I am obtaining a couple of bellows that expand to 10", more than enough and contract to 3 1/2". I will machine nylon bushes to fit the inner and outer ends of the cable and the holes in each end of the bellows and then fasten these in place after packing them with silicon grease. It will be interesting to see how they perform and whether I can keep a water seal under full throttle pressure. Any suggestions as to where to purchase Teleflex at a good price? Thanks in advance
