T top nav light?
Van T
Chesapeake va
Is anyone running navigation lights on the back of their t-top instead of that stupid pole you have to plug in. Jet Pilot has one with rocket launchers but I don't really know if I want the rocket launchers up there.
Alan Crawford
NorCal
I purchased a 7 rod rocket launcher from Stryker with nav and spreader lights. I ran the wires through the tubing and installed waterproof plugs so that I can still take the ttop off when needed.
Eric Ballard
Clayton, NC
I put this light on the front center of my bimini top. I had to cut the bimini top a little to mount it (I resealed the cut edges with a lighter) The mount stays up and when I need the light I grab it from the glove box and it attached with strong magnets.
No more stupid pole light that is hard to get out of the ski locker and the light on top of the bimini is higher and more visible than the pole light.
https://www.amazon.com/Navisafe-920-Clamp-On-Rail-Mount/dp/B002ZRPK3I/ref=sr_1_12?ie=UTF8&qid=1496895752&sr=8-12&keywords=navisafe+light
JetSet407
Orlando, Fla
Does the Stryker Rocket Launcher work well with stock bimini top? Looking for rocket launcher style rod holders that will work well with stock 2018 fsh sport bimini top. Thanks!
Tailwaters
St Joseph MI
The oem light is garage. Some of the aftermarket t-top makers offer a navigation light. Just need to make sure it comes with adapters that will go down to the smaller diameter tubing that Yamaha uses
