Temporary Ballast
jawsf16
Anybody who uses temporary ballast bags for surfing mind posting up your bag locations? Pics?
I am considering getting a couple of 750# bags and was initially thinking about placing one on the floor and one on the port cushions, but I am concerned about weight on the cushions. I really can't use the under cushion area because it is filled with batteries, amps, sub. Which brings me to my next question, am I crazy to consider putting 750 lbs of water on top of the electronics?
ar240owner
Event Sponsor
Event Sponsor
Yes , that is how we started , I have had no I'll affects with having bags on the seat , and after they are filled up we sit on them !! That's actually fun place to watch the action !!!!
jetboater4life
Rochester, MN 55901
How do you get a 750lb bag to stay on the seat? I put one on my swim deck with tie down straps above and beneath it but I don't want straps tearing into my seats.
I use my stock 212x ballast plus 750lb on the swimdeck shaded to the surf side. I fill my front ski locker and then put another 350 under the front surf side seat. Surf side is starboard for us since we are just plain goofy!
ar240owner
Event Sponsor
Event Sponsor
I just set it on there , while it fills I stand by it so it doesn't fall off , but once it's full it just stays there
ar240owner
Event Sponsor
Event Sponsor
Mine is a big square block when it's full
ar240owner
Event Sponsor
Event Sponsor
I'll snap a pic next time out
jcyamaharider
Event Sponsor
Event Sponsor
Rosebud, Mo
20140614_141948.jpg Yep mine just stay in place also.
Glassman
The only temporary ballast I use is breakfast. That being said, 10 full adults can really weigh the ass end of my boat down, so it's nothing to sneeze at!
I just slide everything and everybody to the back of the boat and put the tabs down and throttle up just to the breakover point.
Throws a nice little wake for the kids. If they are happy my wife is happy. And you know the rest!:winkingthumbsup"
jcyamaharider
Event Sponsor
Event Sponsor
Rosebud, Mo
jetboater4life
Rochester, MN 55901
Same 750 fly high
I surf goofy so there might not be enough room on the starboard side to put that bag. I could try across the back seat again.
jcyamaharider
Event Sponsor
Event Sponsor
Rosebud, Mo
"smacks self in head" That is right....forgot about that. I did put my 550 pound aerial bag on my goofy side one time. It fit just fine.
Yamaha242lsdallas
Fort Worth TX
What is the best way to tie down the bags if using them on the transom? I'm worried of I use the grab rail used for pulling you up from the ladder it will put to much pressure on it. Also what is the pull strength of the tow cleat? if I use that as part of the tiedown setup will a 800 lb bag put to much pressure on it? Only other option i can think of is coming off of the tower from both sides...?
How is everyone else doing it, assuming others put a bag on the transom.
KXCam22
Kamloops BC
I used a couple of tie downs with a short strap between to hold my 800lb sumo on the back deck. I have seen picks of cargo nets that looked great. Cam.
jcyamaharider
Event Sponsor
Event Sponsor
Rosebud, Mo
I just hook my tow cleat, under and around the bag, then tie off to the side grab handle next to the port seat. It will not be much pressure, you are just getting it not to move.
Yamaha242lsdallas
Fort Worth TX
Thanks, I tried out a few ways and happy with the way its working tie off from the tow cleat and grab handles on the transom. plus its easy to unscrew the plugs to empty while i pump out the other bag under the seat at the same time.
With my batteries moved and i glued in protective panels all the way to the aft section on the port side i can fit a 800# sumo sac on that side under the seat and tie the other 800# across the transom seat. It puts out a great wake now, but I still can't go rope-less. I wont hijack this thread with different board types but bottom line is I'm getting around a 3' wake straightline and that should be more then enough to wakesurf i would think.
Happy with my placement but not happy with my board.
scokill
Rowlett, TX
I've used rope to hook to lower tow point, set bag on top of said rope, and tie other ends to tower. I've also used a pair of ratcheting straps. I have a new 800 lb bag and I'm going to create something custom so we don't get out there and wing it.
OrangeTJ
El Dorado Hills, CA
I have my 800 lb Sumo Sacs under the port and starboard seats in our SX210. I don't see any reason to have them up on top of the seats. Of course, if I want to run more weight than that on either side I'll need to put one up there. If you're just getting the two bags, though, why not put one under each seat and pushed back as far as possible?
