Temporary Exprt
Kross
thinking of posting about all the times I've had to become a temporary expert, and never wanted to. For example... Basically, if you want ______, then order ______. then do this <video>. I want to make this because I wish I had these instead of spending countless hours becoming a temporary expert. I would have much rather watched a crazy detailed video, and bought the stuff on the amazon links. I'll continue to think this over and get a big post going. This forum has helped me so much, would love to try and give back a bit. thx all.
- LED interior lights
- battery charger (there is WAY more to this than I would have ever thought. You got to get a smart charger. My smart charger is truly amazing. I go out, switch to my second battery, and drain the thing down, then switch back to my starter battery and go home. Once home, I charge the batteries back up and I'm good to go. The smart charger does this perfectly. more later)
- new sound system (amp, speakers, head unit, subwoofer, all wiring)
- transom speakers (my most aggressive, and honestly the single best thing I've done to my boat. We pull up to the beach, back the boat up and BAM, transom speakers rock-it-out. A perfect solution if you dont have a tower for tower-speakers)
- Trailer
- Oil change
- Spark Plug change (i've never changed spark plugs on anything before. Not mechanically inclined at all. You can imagine how intimidating this was the first time. Now its easy)
- Kross
sounds like a great idea, be sure to check FAQ section to see if somebody hasn't already done it or what you can do to fill in any gaps to make it better,
you may want to check the JetBoatPilot channel on YouTube... he has done a number of such videos
thoughts, @JetBoatPilot ?
