Texas Boat Owners (Trailer Inspection)
Cory
Lake Kiowa, TX 76240
Scottintexas
Corinth, TX (DFW)
ugggggghhh! :yuck::banghead::banghead::banghead::banghead:
more hoops to jump through,
GTBRMC
Waukesha, WI
Ughhh! Good luck with that, Texas jetboaters.
This reminds me of Wisconsin's implementation of its version of the "cover your load law."
WI forces all dump trucks and similar to have tarps to cover aggregate loads like gravel, sand, etc. from raining on the cars behind them (and spilling out into the environment).
However, WI has nobody enforcing this law and, apparently, never intended to. Let's add all the cost without any of the benefit. Yup, sounds like a plan (eyeroll).
Scottintexas
Corinth, TX (DFW)
and even worse, not all stations will do the safety check, so goodbye to my local shop who I tried to build a relationship with, hello to poke you in the eye because the light "isn't bright enough" or whatever they make up,
http://dps.texas.gov/RSD/VI/VIactiveStationLocator/viSrchResults.aspx
Endorsements:
1yr
Annual safety inspection certificate
2yr 2 year certificate issued to new cars
ASM Annual emission inspection certificate.
OBD Annual emission inspection certificate
TSI/OBD Annual emission inspection certificate
TL Trailer certificate
MC Motorcycle certificate
CW/CT Commercial Windshield/Trailer certificate
Search Results for GARLAND
CLICK a 'Station' in the Grid below to see station details and a map
1 2 3 4 5 6 7 8 9 10 11 12
Station Address City Phone Endorsements
2000 AUTO REPAIR 3732 W WALNUT ST GARLAND 972-276-7342 1YR,OBD
205 AUTOWORKS 205 E BUCKINGHAM RD GARLAND 214-550-0214 1YR,TLMC,OBD
5 STARS AUTO INSPECTION & TIRES 438 S. KIRBY ST GARLAND 682-558-9017 1YR,OBD
A & S INSPECTIONS 3209 S SHILOH RD GARLAND 214-770-7498 1YR,OBD
AAA TIRES & WHEELS 101 E BUCKINGHAM RD GARLAND 972-900-2039 1YR,ASM,OBD
ADVANCED ALIGNMENT & AUTO CARE 2647 S GARLAND AVE GARLAND 972-278-0400 1YR,OBD
AMERICA AUTOPLEX 2729 S. GARLAND AVE GARLAND 214-779-1885 1YR,OBD
AMERICAN TINT
Cory
I'm hopeful mine will do it, they pass my Dune Buggy every year, so a trailer "should" be a piece of cake.
PEARCE
Kaufman, TX
The answer is yes Cory. All they do is make sure your brakes and brake lights work. It only cost $7-8. I've gotta do the same with my camper.
Cory
How do they test the brakes? Pull the power and try to back up?
PEARCE
Kaufman, TX
I'm not real sure. My father in law just had his camper inspected and he was told to use the trailer brake controller override lever to stop the rig. Ours are obviously surge so you may be right about pulling the power and backing up an incline.
jawsf16
Will any inspection do this? Seems like a bit of a PITA but it does make sense to keep junk off the road....
PEARCE
Kaufman, TX
Call ahead and check before you go. Not all of them will do them or even know what to do.
Scottintexas
Corinth, TX (DFW)
jawsf16
Thanks Scott and thanks Cory. I had no idea about this!
KXCam22
Kamloops BC
I am heading to Houston in the morning. First time. Cam.
Scottintexas
Corinth, TX (DFW)
@KXCam22 my condolences,
what part of town are you going to? how long are you staying? The wildflowers should be blooming so you should get to see some beautiful blue bonnets and butter cups!
PEARCE
Kaufman, TX
X2
Get ready for lots of heavy traffic and some rude drivers too. Enjoy some good Tex-Mex while you're in town.
scokill
Rowlett, TX
I just did this yesterday to get my registration renewed. I called around. There were a couple of Valvoline Oil change places a little ways from me that did it, and I ended up finding a local owned auto repair place closer. Took longer for the guy to enter the info in computer than the inspection. If you look online it has the details. Lights, safety chain, break away brake cable, brake system. Pretty much it. GVWR of 4500 lbs or greater...not all trailers but obviously our boat trailers. I was told you have to show proof of insurance on the tow vehicle but they didn't look.
RForester
Pampa, Texas
Go to a mom and pop and the might just not even look at it. That was my experience.
jawsf16
Well I got the trailer inspected this morning. Super easy to do. Went to a small place in Pottsboro near Texoma. The gal had me drive forward ten feet and stomp the brakes to see that they did something. we checked the lights and showed her my truck insurance. She got the trailer vin and make and input the info to the computer. $7 and ten minutes. It was a nonevent.
If any texoma boaters want the info on where I went, let me know. It was about a mile from Brookshires and right next to police and fire stations.
PEARCE
Kaufman, TX
I'm taking mine to a local place here in Kaufman in the morning. Then I'm going to get one of the wheel bearings repaired by another local business because I'm tired of constantly having to add grease to it. The rear seal seems to be the culprit since there's grease inside the wheel.
Wayloncle
73703 Enid, OK
I guess it's about time I switched mine to TX plates, I found a place a few miles from my storage lot that does trailers. Sucks that I have to get my camper out of the storage lot to get it done, it's in a different storage than my boat and a pain to get in and out of its spot:-/.
I talked to the guy about doing my truck as well, he said we'd have to unhook the boat and pull the truck inside and then he takes it for a drive down the road to for the inspection:-/ I had no idea the vehicle one would be that involved.
