Mike190
- Franklin, Ga
- SX
Not sure if it will fit as it starts to curve the lower you go. I removed the sticker when I did mine. I did lower it some as I didn't want my hand banging the top. I also placed to small remote push switches to turn the bow speakers on/off (when people sat there they said it was too loud).Below the sticker looks good to me
Any pics of yours I'm leaning to the bottom because it has more flat area and I can almost reach it from the back with my handNot sure if it will fit as it starts to curve the lower you go. I removed the sticker when I did mine. I did lower it some as I didn't want my hand banging the top. I also placed to small remote push switches to turn the bow speakers on/off (when people sat there they said it was too loud).
The head unit is under the passenger side dash in the factory location so had to put a wired remote on the helm so I can control it while drivingWhere did you put the stereo? My remote is on the swim platform. It’s very convenient there.
I did it helps getting light in there lol but I have short arms so have to go in on the bottom to reach. I wish they would have put a door on that side from the factory (yes I do plan on putting one in just haven't done it yet).Same location I used on my 190.
Remove the now setback. Makes getting in there, just slightly less bad.
I had just installed that door on mine when I put the remote in. It makes a HUGE difference!I did it helps getting light in there lol but I have short arms so have to go in on the bottom to reach. I wish they would have put a door on that side from the factory (yes I do plan on putting one in just haven't done it yet).
I bet lucky for me I can at least fit under the front seat if I lay back into it and slide in. Its tight but I can get in there good enough to put the bracket on.I had just installed that door on mine when I put the remote in. It makes a HUGE difference!
LOL, that's exactly what I did. Easy getting it, hard to get out.Well I got in there and got it done. There is silicon on the radio I did that because some of the reviews said the screen gets loose and leaks water in just got to go back and trim the access. I got a few wires and stuff to finish tiring up then I am going to to a write up on the installation. Thanks everyone for their input.View attachment 112554View attachment 112555View attachment 112557View attachment 112558
That it is true that was like the 5th time I had been in there between deciding where to put it and actually putting it inLOL, that's exactly what I did. Easy getting it, hard to get out.
Its silicone some of the reviews on that remote said the screen gets loose and let's water in. Once it cures I will be trimming it back to where you don't notice it.What is all over the screen on the remote in the last pic?
