Throttle Plastic Cover Plate
greenwood
Lake Geenwood
The throttle plastic cover plate that moves with the throttle on my 165 is very noisy and squeeks like crazy.
Tried lubricating it with silicone spray and took off cover plate and loosened it a little with no luck.
Any suggestions ?
Thanks.
tdonoughue
The Woodlands, TX 77381
Try a crayon. Match the color and then 'color' the affected area. Sometimes the wax holds better than the silicone...
Speed_Freak_039A
HO Impulse
You mean the silver plated? Nothing moves with the throttle that I remember
greenwood
Lake Geenwood
It is the black plastic material that is inside of the silver plate that moves when you move the throttle
Bry-n-Jess-165/HOI
Chicago
HO Impulse
Mine was also noisy, I used the silicone. If you look at the area you can possibly see an area which is touching and leaving a little line, I used finger nail file and filed the plastic tip which was touching and making the squeeking .
Speed_Freak_039A
HO Impulse
Gotcha. Yep. Its all part of the throttle handle though which is why I got confused. I used WD-40 and then cleaned it off.
