Thru-Hull Fitting Article
Brad_Ct
Alva Fl
I read a article in the December Boat U.S. Magazine concerning Thru-Hull fittings failures and they say that only bronze and Marelon (plastic) should be used for below water line fittings. I know a lot of you including myself have used stainless steel fittings especially for scuppers. I also read somewhere else that if stainless is left in a oxygen free atmosphere it will eventually rust and fail.
I know that most of us don't leave our boats in the water long enough for this to happen but thought it might interest some of you.
swatski
North Caldwell, NJ
My thinking would be: if you wet slip, especially in salt, the steering/throttle cables and other AK fittings, but also pump bearings and shafts, will rust apart and wear rings will swell before the stainless steel scooper fails..., no?
