For all those people who find it more convenient to bother you with their question rather than search it for themselves.
bfy.tw
Sorry, couldn't help myself
There are tons of posts here about the Thrust Vectors, the Thrust Vector Wake setup, and the Lateral Thrusters. All 3 are different products with different intentions, despite having very similar names. @JetBoatPilot can help explain. He frequents the boards, and I'm sure will have some info.
Thrust Vectors have nothing to do with the wake but is all about better steering control at low speeds. They work great. Several write ups here. Serch is your friend...
It's a fair question, but I do wonder after reading all the posts in the multiple Yamaha boat pages on Facebook, How can folks miss all this attention that these third party companies are getting for providing an amazing solution for Yamaha's known poor steering?
It's like missing an oil thread. If this thread is followed up by what Oil should I use, or how often should I change my spark plugs, then we know someone with a rock for an address is just trying to get their post count up. (smile)
The Jet Boat Pilot Thrust Vectors XV coupled with Reverse Thrusters are great enhancements. However, servicing or removal can be a nightmare due to incorrect use of SS button head screws (5mm allen wrench). Due to galvanic corrosion over time, the button head screw threads has potential to seize up with mating aluminum casting material. The button head does not have adequate meat for strength in the application. The head easily gets rounded or stripped using 5mm allen wrench. It can make you cry in the removal process of the thrust vectors, lateral thrusters, gates and nozzles. There are six (6) button heads (dual engines) with varying lengths, I was able to remove three (3) gingerly and easily. Also able to remove one (1) stripped head by making a slot via Dremel Tool and using an impact gun. I still have two (2) screws to remove in the same manner. Extraction may need drilling, what a nightmare. Later on I will be replacing the button heads with hex heads for better strength. My thrusters are only 3 years young. Accordingly, I suggest replacement of the button heads with hex or socket head bolts while you can to preclude future nightmare.
