Thrust Vectors
SB78
I have a 2019 SX190. For those of you that have installed thrust vectors, has it made a noticeable difference?
anmut
212S
Look underneath your pump, you should have Yamaha's version of the thrust vector. No need for aftermarket.
SB78
I know it has the articulating keel, but I'm curious to hear from those that have also installed thrust vectors whether it has made a difference in low speed handling.
Babin Farms
Lower Alabama
anmut
212S
Yes, you have the AK and Yamaha's version of the TV installed. With that setup from the factory I don't think TV would even install on your pump. TV are only for reverse handling. If you want improved forward handling, try the Cobras.
SB78
To clarify, I'm not asking about the lateral thrusters. I'm asking about the Thrust Vector X low speed steering enhancer.
anmut
212S
Makes more sense now! Yes - those will bolt on and people seem to really like those or the Cobra fins. I went Cobra because they seem to be a bit more heavy duty. Thrust vectors look nicer, IMHO. Do a search here, there's probably 1000 threads on this debate. Also, both manufactures are very active on this board.
SB78
From what I've read, doesn't really seem you can go wrong with either one. I decided to go with the Thrust Vector X and just ordered it. Thanks for the quick feedback anmut.
anmut
212S
Anytime! I do envy your color choices - in the off season I think I'll have mine powder coated.
mwalker4
Delaware County, Ohio
One thing to check on the Thrust Vectors. Do they block your lateral reverse thrust? Last years Cobra's did block the lateral thrust more than I wanted and he came out with an improved fin which is curved to allow more lateral thrust in reverse. It has been a very good improvement in reverse steering while maintaining the forward slow speed advantage of the fins.
