- Lake Ray Roberts, Texas
- Boatless
- NA
- Other
- NA
The system is a TireMinder setup available at Camping World. It was in my coach when I bought it and is aftermarket. The system I have will monitor up to 22 tires. I have 6 on the coach and bought 4 more sensors. I will use those sensors on the boat trailer now and later on the car we will flat tow behind the coach. I have had a few issues with this. The sensors are not as accurate as I would like and I have lost signals before. The manufacturer said due to size and interference by all todays wireless devices, that a booster was needed...so another $35 and two days to find a suitable location to tap 12v from the coach both conveniently and without draining my batteries on the coach when not in use! I found the last 12v light fixture on the line in my closet. I cut the fixtures wiring instead of the coach harness. I added a simple toggle switch marked on/off on the housing of the fixture and wired in the booster. Works great! I am sure I will get a good signal even from the trailer.
